Bio fuels.
Old May 9, 2008 | 12:53 PM
abarmby's Avatar
abarmby
Default RE: Bio fuels.
ORIGINAL: minex
ORIGINAL: redtruck2500
It is called Algae and feeds off of the moisture that is in fuel. If you keep the moisture to a minimum , you can reduce the chances of growing algae in the fuel.
Just a small correction. Algae does not and cannot grow in fuel tanks. No light -- no algae. What does grow in the tank are microbes, which feed on diesel fuel. This is what clogs the fuel lines and fuel filters.
http://en.wikipedia.org/wiki/Diesel#...s.2C_and_water
Correct.
Algae need lightfor the process ofphotosynthesis as they are technically plants.
The process of photosynthesis, providesalgae with the fuel for life, namely sugars.
Microbes and bacteria are organisms and get food/fuel from other sources.
Al.
Old May 9, 2008 | 01:15 PM
redtruck2500's Avatar
redtruck2500
I sit corrected.
