squeeking
Old May 9, 2008 | 10:24 PM
irelandshemi's Avatar
irelandshemi
Default squeeking
front end is squeeking whenever i hit a bump or turn any reasons why and how to fix it?
Old May 9, 2008 | 11:12 PM
adavis4's Avatar
adavis4
Default RE: squeeking
yeah i had the same problem.....over speed bumps it scrubbed and made a squeaking sound. I took it to the dealer and they said it was a common from, they did a little grinding and it is gone...I think it was the control arm or something rubbing as the suspension was traveling up and down
Old May 9, 2008 | 11:14 PM
irelandshemi
i happens even when im just driving now, or when i turn my wheel from left to right
Old May 10, 2008 | 08:11 AM
satansfx's Avatar
satansfx
Yea mine is doing the same thing. Just started to about a week ago. I need to get it to the dealership before my warrenty runs out, but my luck they will try and charge me to fix it.
Old May 10, 2008 | 02:42 PM
irelandshemi
if you dont mind posting what the dealership does to fix it i would appreciate it
Old May 10, 2008 | 08:54 PM
hemiyellow's Avatar
hemiyellow
DC Insider
prolly sway bar bushing....unbolt the sway bar, remove the bushing and put some lube in where the sway bar goes....thats what we did at the dealership for **** like that....99% of the time it fixed it
Old May 10, 2008 | 08:56 PM
irelandshemi
any special lube you would recommend
Old May 10, 2008 | 09:01 PM
hemiyellow's Avatar
hemiyellow
DC Insider
we used some stuff called "Sil-Glyde"...comes in a blue Napa tube....it's waterproof so thats the main reason we used it, plus it doesn't gum up or freeze....some pretty good stuff....i use it quite a bit on various things on the truck....like the brake pedal squeeking lol
Old May 10, 2008 | 10:17 PM
irelandshemi
ha thats good stuff then ill give it a try
Old May 10, 2008 | 11:00 PM
kyo77's Avatar
kyo77
Just thought I would add my two sence in also. I had my neighbor take a look at my dodge because it just started doing the exact same thing. The verdict was the upper and lower ball joints are shot i.e ripped and torn gaskets and dry as a bone. I'm going to try and get a price on them, don't know if I can get the individual OEM ball joint by its self or if I have to get the the whole control arm. Good luck with yours.
