Flip-up arm rest center console disassemble
Old May 11, 2008 | 10:27 PM
lilfroger's Avatar
lilfroger
Default Flip-up arm rest center console disassemble
Anyone take the plastic liner out of their center console? I have a lock box I'd like to put in there but I'd like to remove the liner to see if there is something more stable than plastic under it to mount it to.
Old May 12, 2008 | 10:26 AM
KrazyBrian's Avatar
KrazyBrian
Default RE: Flip-up arm rest center console disassemble
theres steel under there, but not much room at all (the lock box should fit in the plastic or be designed to replace it), i also believe there's a control module of some sort under there as well
Also, the seat latch is integrated into that plastic liner, so if you pull that, it will not latch properly
Old May 12, 2008 | 10:37 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
ORIGINAL: lilfroger
This is about the best I can do for you, as it shows whats under everything....but I dont think it will work for what you want to do personally...
https://dodgeforum.com/m_1254583/tm.htm
If it was me, I'd bolt the bastard down to the chassis or something.....
