biggest tires
Old May 23, 2008 | 07:55 AM
nbstriker10's Avatar
nbstriker10
Default biggest tires
what are the biggest size tire you can get without having problems if all im going to do is get a 2" leveling kit or keep it stock? i know you need to lift it to be able to get big sizes but what is the biggest i can go giving that information...
Old May 23, 2008 | 08:43 AM
mmstar23's Avatar
mmstar23
Default RE: biggest tires
with a leveling kit, and if its a 4x4, and you keep stock rims you can clear 35's
actually romeosoldier cleared 36's with just a leveling kit. you need wheel spacers for those though
Old May 23, 2008 | 10:14 AM
HammerZ71's Avatar
HammerZ71
33's will clear easily with it stock and not hinder you at all. I had 33's before lifting and did a good bit of hard off-roading with no issues. You can clear 35's with a level kit and it'd be fine for normal use, but will rub a little when you cut it all the way. It will also hinder you a good bit if you take it off road on all but easy trail riding. Even with a level kit, I'd recommend 33's if you plan on any type of off-road activity...
Old May 23, 2008 | 11:28 AM
jonnymagnum's Avatar
jonnymagnum
I have 35's and I just cranked my T bars so it wouldnt rub anymore. now they just rub a lil bit at full turn.
Old May 23, 2008 | 01:33 PM
nbstriker10
yea ur looks nice (jonnymagnum) from the pic in your sig... so i wouldnt be too bad just with a level and 35s... maybe some rubbing issues on turns where i cut the wheel hard...
Old May 23, 2008 | 04:50 PM
Romeosoldier03's Avatar
Romeosoldier03
i didn't need wheel spacers to clear them...they cleared..oh so barely did they clear......I put the wheel spacers on it when I put the 3" body lift on....it just lookd better with them on and maybe with a lil flexing it would be ok off road.....and the brand of spacer is "UNKNOWN" some guy local here makes them himself as I was told today....when i asked what brand they are....I picked up one of the ones off the shelf they had and wow...a huge difference...my spacers prolly wiegh round...5 lbs a piece!! those that I picked up where very light...i wouldnt trust them others....but mine....I trust them. I've towed with them....and played with them.....no problems...and no readjusting the tightness either.....
Old May 24, 2008 | 01:53 AM
nbstriker10
im still confused on what sizes i can fit haha... not only that, but is there a site besides tirerack.com and discounttiredirect.com that i can find these size tires?
Old May 24, 2008 | 04:13 PM
nbstriker10
anyone on where to get tires besides those sites??
