strobes
i got some strobes yesterday, nothing real nice like the 90 watt ones you see from whelen or anything you see in police cars, but some fairly bright LED ones. now theres a little box that controls the speed and pattern of the lights. from the box theres a positive and negative that goes to the battery. and of course wires that come from that, that go to the bulbs (these just plug in so i understand that part) now i also understand the battery wiring. but i have 2 sets, totaling 8 bulbs, 2 control boxes. i want a switch to turn the 2 boxes on and off at the same time. can someone draw me up a quick diagram on paint or something? do i need a 4 prong switch....? or what? please help me out guys
no, I think you just splice the positive wires of both boxes together after the switch. make sure your switch can handle the amps for both boxes (should not be a problem at all with LEDs).
BATERY-------SWITCH---====TWO BOXES===Ground
Or if you're good at soldering connect them right at the switch
BATTERY---SWITCH===TWO BOXES===GROUND
I would get a DPST (Double PoleSingle Throw) switch. Run the 12v to that, then from the other contacts to each box.
OR, you could get a DPDT switch, use some diodes and if1 box can control all 8 bulbs, depending on the switch position you could select a "slower" or a "faster" flash rate.
Example:
1 box set to fast hooked up to the "up" position
Middle position is "off"
The other box set to slow hooked up to the "down" position
You put the switch "up" and they all flash fast, you put it down, and they flash slow.
Example:
Be careful with strobes on your vehicle. Depending on what state, if you get caught with them on you will be charged with impersanating a police officer, lose your license, and possible lengthy jail time...
thanks guys. im gonna go with xfeejayx's route. seems easy enough and works.
strobes are only for show. on road use will get you jail time, and they cant be red or blue. mine are all white and i can use them as long as i dont pull people over or run red lights and that type of stuff (HAHAH)
Not to sound rude, but what is the fascination with using hide-a-way strobes/leds for show use? Typically they are used for a purpose such as construction vehicles or emergency vehicles.
Trending Topics
Alright, seems fair enough I guess. Just be careful and make sure to avoid the urges to turn them on while on the road, either from your own desire or from peer pressure. they may "look cool" but they will get you in a heap of trouble real fast and no cop is going to be cutting you slack if you tell him you have them on your truck because you've always wanted them and thought they would be cool to have on your truck. Strobes aren't really meant to be a play toy, they are viewed as a tool of the job by emergency workers such as myself. Not trying to sound rude on my first few posts, I just felt I should jump in on this topic.
no worries dude. this forums pretty opinionated and if you take it personally, maybe you shouldnt be here, so dont worry about giving your opinion man. and ya i know not to use it on the street and all that so im not worried
