MegaCab with 2" Leveling Lift Kit
Old May 30, 2008 | 04:54 PM
zfshrmn's Avatar
zfshrmn
Junior Member
Default MegaCab with 2" Leveling Lift Kit
I just added a 2" Leveling Lift Kit from top gun customz and I want to share some of the pictures I took.
I did not wannted to spend money on the jack stands cause I probably would never use them again so I went to lowes and got me for blocks @ $1.35 each
Just removed the track bar bolt
removed lower bolt from shocks (this one is driver site)
remove upper nut from sway bar
Remove vent line and three nuts from shock tower and remove shocks and tower from truck
lower the axle and remove the coil springs
now you may need to compress the coil springs in order to put them back with the new spacers, here is I did, after I took them off I had to put them back without the spacer on and jack my truck up so the springs will compress, after the were compress I tied them so the would not uncompress once I lowered the axle and I'll be able to put the spacers so I did it and it worked.
after you do this just start put everything back were it was and you are done next take it to a shop for alignment.
Before
After
Before
After
The End
Old May 30, 2008 | 06:24 PM
justntexas07's Avatar
justntexas07
Default RE: MegaCab with 2" Leveling Lift Kit
Nice job, looks great. Now all you need are some bigger tires to shove under that thing!
Old May 30, 2008 | 07:21 PM
zfshrmn's Avatar
zfshrmn
Junior Member
Thnx, I know I want to put 33 but I'll have to wait a couple of months for that.
Old May 30, 2008 | 08:40 PM
jonnymagnum's Avatar
jonnymagnum
looks good. and ya, you need some bigger tires underthere
Old May 31, 2008 | 12:57 AM
1 Big B's Avatar
1 Big B
Just to give you example the truck in signature has 35s on it. Looks great man
B
