Towing,Capacity on a
anyone have an idea were i could find out what is the towing capacity on my 05 ram 1500 reg cab long bed with the 4.7 eng, 5 speed auto, with the 3.55 rear end and 245/70/17 tires. i have been looking but have yet to find anything on the capacity of my truck.
thank you for any and all of your help.
you are good for 6550lbs on a slt 4x4 reg cab long bed
http://www.jasperjeep.com/towing_information.htm
this site will give you more info if you need it
Dodge calls it good for 8900-8950 lbs. depending on setup.
You won't be able to get out of your own way pulling that kinda weight with it, but...........
Dodge spec site:
http://www-5.dodge.com/vehsuite/Vehi...u&adid=u&rid=u
Dodge spec site:
http://www.dodge.com/towing/D/vehicl...peed+Automatic
thank you for the link, all is good now. with my setup the site says i can tow 6600lbs but if i change to a 3.92 rear axle i would be able to handle 7600.
thanks.
thanks.
And by doing so you raised your ability to tow more.... I also have the 4.56's installed and can tow more than most trucks on the road easily with my 4.7L.... But if your afraid to go up to a 4.56... then I would take Reorg up on those 3.92's.... the 4.7L NEEDS gear to keep itself in its powerband... Im getting better fuel economey with my 4.56's than I was with the 3.55's.... and I know Reorg is getting the same results over his 3.92's.... (Sorry bro I know your trying to sell those 3.92's) So If you can tow more (ALLOT MORE) get better fuel economey and go 0-60MPH a full second faster... its just a WIN WIN WIN with the 4.56's...
Ohh yeahh... NICE SITE!
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
