Nav conversion
Anything should be possible. But it's probably not just a plug and install. I'm sure there are addtional plugs and wiring you have to install(navigation) and so forth. IMO I would buy an aftermarket head unit. Now if it's free, then i would try to make it work....
If you have an 06-08 it is not that bad.
You only need the head unit, DVD Disc + antenna and the new bezel.
The other cables in there just plug in. You mount the Antenna to the factory mount in the dash and you are set.
