15,000 mile differential service
Old Jun 5, 2008 | 07:03 AM
MikeHTally's Avatar
MikeHTally
Default RE: 15,000 mile differential service
Sounds about right maybe even a hair on the bargain side. When I changed my diff fluid (2WD) with a deeper cover, it used four quarts of Mobil 1. Including the friction modifier, it came to $62.
Old Jun 5, 2008 | 09:52 AM
RamItOne's Avatar
RamItOne
mikeH
jd has a 4x4 so thats dirt cheap or he just forgot about the front...
Old Jun 5, 2008 | 12:10 PM
NYPANAMA42's Avatar
NYPANAMA42
Along the same line, I think i may need a new Differential, can anyone advise of a good shop in the Maryland area? I was hoping that i wouldn't have to get a new one especially with the economy the way it is right now, but just in case i have to, knowing a good shop that is reasonable will be helpful.
Old Jun 5, 2008 | 12:24 PM
bdhuntr's Avatar
bdhuntr
This is my opinion, so feel free to disagree:
I think servicing diffs every 15K miles is a titanic waste of time and money. Unless you submerge them and introduce water into the gears, gear oil pretty much never wears out. I've drained rears at 100K and the lube looked as good as it did when first put in.
However, when you are dealing with a lifetime warranty, they gotcha by the short hairs.
