Gears for Drag
Old Jun 7, 2008 | 07:21 AM
FtpHemi's Avatar
FtpHemi
Default Gears for Drag
Need some helpI want to put some gears in my truck and it has the stock 3.92 will 4.10 make a difference and are the 4.56 too low?I know some people put those gears (4.56) on the lifted tucks with big tires but im running the stock 20 on the stock tires (275/55 R20) I think. Gas and topend is not a issue, its not a daily driver its mostly for the track.
Old Jun 7, 2008 | 07:57 AM
MikeHTally's Avatar
MikeHTally
Default RE: Gears for Drag
3.92 to 4.10 isn't enough change. 4.88s or something in the 5s will be your better bet. You'll need way more than just that for the track, though. You're going to need some big power.
Old Jun 7, 2008 | 10:14 AM
ce2flaco's Avatar
ce2flaco
If he's driving a half ton then 4:56's are the lowest available. They just don't make alot for the 9.25 Chrysler rear.
Old Jun 7, 2008 | 12:05 PM
FtpHemi's Avatar
FtpHemi
Yea ist 1500 scsb. What kind of e.t. gains should i get with them? Im currently hitting 14.3-14.1 spinning of the line [sm=gears.gif]so i also need to fix that with some slicks.
Old Jun 7, 2008 | 01:56 PM
HammerZ71's Avatar
HammerZ71
The strip is all about making rpm's fast, the 4.88s will do this. I wouldn't even think anything less than 4.56. And YES, 4.88s are available from a number of manufacturers including Yukon and US Gear...
Old Jun 7, 2008 | 02:13 PM
mmstar23's Avatar
mmstar23
on airram, he has 4.88 for 2wd's
Old Jun 7, 2008 | 05:01 PM
ce2flaco's Avatar
ce2flaco
ORIGINAL: mmstar23
ahhhh 2wd, i never bother looking for anything other than a 4X4
