2007 mega cab 4x4 headlights
Old Jun 8, 2008 | 09:33 PM
warlord1026's Avatar
warlord1026
Default 2007 mega cab 4x4 headlights
Hi all,
I just bought my 2007 megacab 4x4 duallie. Is it just me or do the factory hi beams suck? I swear i can see more on low beam, than i can with the hi beams. any recomendations?
Thanks
John
Old Jun 8, 2008 | 09:41 PM
ivaskaj's Avatar
ivaskaj
Default RE: 2007 mega cab 4x4 headlights
Take it to the dealer had have the lights adjusted. Do people flash you when the low beams are on?
Old Jun 9, 2008 | 12:34 PM
warlord1026
no, i have checked my alignment. it seems to be alright when i turn on my hi beams they appear to be dim.
Old Jun 9, 2008 | 05:56 PM
ivaskaj's Avatar
ivaskaj
Maybe wiring? It's an '07. Warranty. Dealer.
Old Jun 10, 2008 | 04:41 AM
opposite locker's Avatar
opposite locker
My '08 has a similar problem. The high beams are mediocre at best, and the low beams w/fog lights are actually pretty damn bright... so by comparison, the high beams suck. Instead of messing with things, I'll probably just install some auxiliary driving lights behind the grill and wire them to come on with the brights.
Old Jun 10, 2008 | 08:17 PM
throberts's Avatar
throberts
had the same prob with my new 2008 MC, changed the lights to silverstars and fog lights to silver star ultras....helped alot....especially the brights seeing at a distance.
Old Jun 14, 2008 | 10:43 PM
warlord1026
thanks
to all that replied. I think i will give the selverstars a try. i agree that the low beams and factory fogs are bright as hell. it does make the hi beams seem a little dissapointing when you hit the switch.
Thanks again
John
Old Jun 14, 2008 | 10:50 PM
mmstar23's Avatar
mmstar23
it wont let me post again!
Old Jun 14, 2008 | 10:51 PM
mmstar23's Avatar
mmstar23
depending on the # of the bulb i can get them to you cheaper than retail which is around $55.
Old Jun 14, 2008 | 11:49 PM
dodgenitto's Avatar
dodgenitto
ORIGINAL: warlord1026
thanks
Thanks again
John
I have wired my fog lights to my parking lights! Stock, when you turn on your brights your fog lights turn off, do this and your fog lights will stay on with your high beams! I installed an in-line 5amp fuse! WORKS GREAT! Your fog lights will now turn on with your parkng lights! Problem solved! takes 5 minutes!
https://dodgeforum.com/m_197878/tm.htm
[IMG]local://upfiles/79459/3C7170F3B14F465C9AC82E1634B7FE96.jpg[/IMG]
[IMG]local://upfiles/79459/7244336560404EF2B3EFA4C3670E79BC.jpg[/IMG]
