new 35's rubbing!
Old Jun 10, 2008 | 03:45 PM
evomega08's Avatar
evomega08
Default new 35's rubbing!
I've been told I can put 35's on my 08 megacab with a 2" leveling kit, but now that its all on they rub on the outside of the bottom rear part of the fender. Does anyone have any easy fixes? I don't really want to cut on the metal, and can't afford a suspension lift. The new rims are XD rockstars with 325/65/18 Nitto dune grapplers with a 0 offset if that matters.
Old Jun 10, 2008 | 04:13 PM
antelope's Avatar
antelope
Default RE: new 35's rubbing!
evomega,
first im hoping that your mega is a 4x4. If it is a 2" leveling kit will fit 35s assuming that the offset is identical to the stock offset. The XD Rockstars are not the same therefore you get rubbing. The biggest size your can fit w/o rubbing on those wheels are 33x12.5.
Old Jun 10, 2008 | 04:49 PM
Timmerduder's Avatar
Timmerduder
Mine has the 2" leveling kit with 31570R17's and they rub the mud flaps slightly at full turn only....
based on calculated tire size mineare 35.6" and your are 34.6"
look here http://www.miata.net/garage/tirecalc.html
did you get an allignment?
Old Jun 10, 2008 | 07:40 PM
jonnymagnum's Avatar
jonnymagnum
I have 35x 12.5 and no rubbing after crankin my t bars 2"
Old Jun 10, 2008 | 08:10 PM
evomega08's Avatar
evomega08
I don't know what you mean about crankin your t bars what is this.
Old Jun 10, 2008 | 10:04 PM
04 HEMI 04's Avatar
04 HEMI 04
T bars is sway or somthing but it does raise ur stock height to clear the rubbing.
Old Jun 11, 2008 | 08:07 AM
UP_Boilermaker's Avatar
UP_Boilermaker
ORIGINAL: 04 HEMI 04
Uhhh, No.
'T-Bars' = Torsion Bars = The type of spring used in the front suspension setup of certain 3rd gen Rams.
They are NOT sway bars of any type.
'Cranking the T-Bars' refers to re-indexing the torsion bars to slightly raise the spring rate of them, thereby raising the front end height.
