A/C blows hard on drivers, not pass. UPDATE!
Old Jun 13, 2008 | 11:21 AM
TheUsed801's Avatar
TheUsed801
Default A/C blows hard on drivers, not pass. UPDATE!
Noticed something recently that I never really noticed before on my 02 Ram 1500, the A/C blows out pretty damn cold and hard on my side, but on the passengers side, blows out very weak.
Anyone know how I could possibly fix this myself? I called Dodge and they said it would cost about 400-500 dollars for them to fix.
Ouch.
Old Jun 13, 2008 | 10:06 PM
TheUsed801's Avatar
TheUsed801
Default RE: A/C blows hard on drivers, not pass.
Bump?
Old Jul 12, 2008 | 02:17 PM
TheUsed801's Avatar
TheUsed801
Update:
So I pulled off the dash on the passenger's side so I could take a look at the blend door. It appears to be functioning properly. I have searched and looked at all threads on the forum concerning the blend door. When I turn the **** on my climate control, the blend door responds quickly, and appears to go where it is supposed to. If I apply a little bit of pressure on the blend door, it doesn't give much, which IMO, is a good thing. I'm seriously going crazy, because it's going to be summer here in Oklahoma soon, and temperatures are going to be in the triple digits. Anyone have any more ideas as to what this could be?? I really cannot afford to get this fixed, and I'm not sure Dodge will diagnose it for free, seeing as how it's not under warranty anymore.
Old Jul 12, 2008 | 02:35 PM
John  M's Avatar
John M
Blend controls the hot/cold selection. You want to find the other door that handles vent selection - dash, floor, defrost, etc.
I have never been inside my truck's hvac setup - just wanted to put in my 2 cents.
Old Jul 12, 2008 | 03:57 PM
TheUsed801's Avatar
TheUsed801
The door I'm talking about is the door you're talking about, I believe. When I turn the dial that controls floor, vent, defroster, etc..., it moves. As far as I can tell, it's not broken, but I was wondering if anyone had the same scenario, but when they pulled theirs out, if it was indeed broken.
Old Jul 12, 2008 | 04:14 PM
vipersforsale's Avatar
vipersforsale
the only diagram I have is the one from the service manual which of course shows the dual zone control. It shows the passenger side blend door to be in the center, top location towards the firewall and the drivers blend door to be right in the middle, mid-height right in the front where it should be reachable. To check it you would move the temp control back and forth, this controls the doors position. The mode door actuator is to the left of that, about a foot or so, same level... looks like kinda behind the radio area somewhere.
Dont know if this helps or not since the manual doesnt go into which, the drivers or the passengers is the only one in the single zone setup.
Old Jul 12, 2008 | 04:15 PM
PhotoRam's Avatar
PhotoRam
There should be two doors. One to control flow from the heater core/cooling and one to control flow to the dash/floor and defroster. Not sure if this helps you.
Old Jul 12, 2008 | 04:53 PM
chefred112's Avatar
chefred112
you dint by chance seal the rear vents in the cab that allows for airflow throughout the cab right?
Old Jul 12, 2008 | 06:04 PM
TheUsed801's Avatar
TheUsed801
ORIGINAL: chefred112
I don't even know how I would go about doing that, lol.
And if it helps at all, it sounds like under the glove box the A/C is loud as hell. Roars like a vent above the stove in your kitchen...
Old Jul 12, 2008 | 09:54 PM
PhotoRam's Avatar
PhotoRam
ORIGINAL: TheUsed801
The other blend door is there.
