some questions
Old Jun 13, 2008 | 11:11 PM
RamItOne's Avatar
RamItOne
Default RE: some questions
the front axle is 205mm
there's not a thing wrong with the motor, just run amsoil in it and run 1qt marvel mystery oil in the crank case every 10k or so for 1k miles. Keep the throttle body clean every 15 or 30k miles, 30 would be easier as that's when you change the champion copper plugs. Clean the pcv valve every 15-30k.
If you don't tow much the tranny will last a long time. But replacing the tranny with a beefier one would only cost 2k.
