cats or no cats???
Old Jun 15, 2008 | 11:26 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Default RE: cats or no cats???
wont hurt the engine to gut/cut. you might lose some low end.
Old Jun 16, 2008 | 12:36 AM
Romeosoldier03's Avatar
Romeosoldier03
what's the "non fouling" trick...??? how do u do it?
Old Jun 16, 2008 | 12:43 AM
Pyro's Avatar
Pyro
I Beat Tetris
basically you get a o2 simulator that you replace your o2 sensor with. what it does is tell your PCM that your cats are just fine and it continues operating normally without throwing any codes.
Old Jun 16, 2008 | 12:48 AM
mmstar23's Avatar
mmstar23
ORIGINAL: Romeosoldier03
https://dodgeforum.com/m_1295926/mpa...tm.htm#1295926
Old Jun 16, 2008 | 12:53 AM
daytona1680's Avatar
daytona1680
ORIGINAL: Pyro
o2 simsdont work on the hemi's...we are using sparkplug nonfoulers. drill one out to 1/2" and screw it into another nonfouler, then you screw the o2 sensor into the non fouler that was drilled out and then screw that into the exhaust pipe and hook up the o2..id say 99% of the time it works
