Hot Cold Air Intake???
Old Jun 14, 2008 | 10:25 PM
kutz420's Avatar
kutz420
Default Hot Cold Air Intake???
And Cold Air Intake??? That pipe get hot as ****. Kinda seems like it defeating the purpose. Any body ever put heat wrap on theirs that still looked good?
Old Jun 15, 2008 | 06:01 PM
kutz420's Avatar
kutz420
Default RE: Hot Cold Air Intake???
Any body?
Old Jun 15, 2008 | 06:05 PM
nbstriker10's Avatar
nbstriker10
ive seen someone wrap it once and it looks good when its done right... as long as the air passing trough it is cooler then ur good
Old Jun 15, 2008 | 06:47 PM
AIR RAM's Avatar
AIR RAM
We insulated our AIR RAM systems but they are no longer available. Honestly, you would see GREATER gains by removing the resonator... or intake "MUFFLER" which is otherwise known as the "HEMI HAT" effectively making a FULL LENGTH intake. The Resonator is more restrictive then the filter box you replaced with your current intake.
You can insulate your intake if you wanted to keep the air cooler. YES it is worth the time, some will say the air moves too quickly through the intake to make a difference... although the air moves quickly through the intake, the heat of the intake does radiate into your incoming intake air charge.
SPEED SAFE, AIR RAM
Old Jun 15, 2008 | 06:53 PM
KKYW Ram 7's Avatar
KKYW Ram 7
Hey kutz, is that one of the super cheap ones off ebay?
Old Jun 15, 2008 | 07:12 PM
Junior000's Avatar
Junior000
You are just sucking in hot engine air anyways...
Old Jun 15, 2008 | 07:14 PM
kutz420's Avatar
kutz420
I just bought the truck and it was already on there. I dont know how "cheap" it is.
Old Jun 15, 2008 | 07:23 PM
Junior000's Avatar
Junior000
Get a K&N with the box, itll hellp not suck in so much hot air off the engine. The plastic tubes give you a little more HP over the metal ones also.
Old Jun 15, 2008 | 07:44 PM
KKYW Ram 7's Avatar
KKYW Ram 7
I did not mean to insult your vehicle. I was looking to get one because they are very inexpensive on ebay. I was just looking for imput.
Old Jun 15, 2008 | 07:46 PM
KKYW Ram 7's Avatar
KKYW Ram 7
http://cgi.ebay.com/ebaymotors/02-03...QQcmdZViewItem
