Superchips Shift Points
Old Jun 16, 2008 | 07:20 PM
A05GSHO's Avatar
A05GSHO
Default Superchips Shift Points
I've been running my 07 Hemi in 91 Performance since I got my Flashpaq. I recently upgraded it to get the shift point and rev limiter options. Tonight I screwed around with it. I set the rev limiter to 6000rpm, 1-2 WOT shift points to 5700rpm and the same for the 2-3WOT shift point. I took it for a ride and the tach was showing that it was shifting at around 5600-5700 at both shift points. She seemed to wined out nicer and shift harder and just all around perform better. So when I got back home I plugged the Flashpaq back in and went to view settings and it said the rev limiter was set to stock so I went to power level/options and 1-2 was at the low setting as well as 2-3. Does it not show you that you origanally set it at 5700 at both shift points?? Am I doing something wrong??
Old Jun 16, 2008 | 11:36 PM
jeepsterbdk's Avatar
jeepsterbdk
Default RE: Superchips Shift Points
Must go to the screen that says program and program it after selecting your settings.
Old Jun 17, 2008 | 08:32 AM
A05GSHO's Avatar
A05GSHO
Thanks.....my bad that did it. Guess I just can't follow instructions LOL.
Old Jun 17, 2008 | 08:59 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
ORIGINAL: A05GSHO
Lol, imagine how great it would ahve been if you programmed it!! stock redline/shift is 5800 anyway.
Old Jun 17, 2008 | 06:59 PM
dinkenflicka's Avatar
dinkenflicka
I've got my own programmer that I'll sell for half of superchips. All you need to do is hold it near your parking brake and it'll program wirelessly. I call it Placebo Effect if anybody is interested.
