What's the best way to lower and still tow.
depends on how low you want to go....if u just want low enough to make it level, then a 2" lowering shackle will be the best....if you want lower then that (like a 2/4 drop) then you will deffinitly want air bags for the rear.....i would still consider airbags for the rear if your only gonna do the shackles, cause it will really make a difference in how much better it rides, and you'll be able to put a little more in the bed and haul more
