How do I remove the Infinity amp from the dash??
Old Jun 28, 2008 | 11:04 PM
HemiJay's Avatar
HemiJay
Default How do I remove the Infinity amp from the dash??
Hi, I am new to Mopar overall and am a recent convert from Chevy thanks to a friend.
I am trying to figure out how to get the Infinity amp out from behind the dash board. I have already removed 2 screws from the front, but there is still one holding it on and I cannot figure out how to get to it, or where it is.
[IMG]local://upfiles/92039/23F8F1DD7A6F42A6A9BA1F5843016730.jpg[/IMG]
Old Jun 29, 2008 | 07:25 AM
lxman1's Avatar
lxman1
Site Moderator
Default RE: How do I remove the Infinity amp from the dash??
https://dodgeforum.com/m_1288989/tm.htm
Old Jun 29, 2008 | 11:17 AM
HemiJay's Avatar
HemiJay
Thanks for the thred, but he never got an answer either and had to give up on the idea....Does anyone out there know how to do this??
Old Jun 29, 2008 | 12:09 PM
kenihemi's Avatar
kenihemi
In an 04 ram (you didn't say what year your truck is) you need to remove the center bezel of the dash, then remove the 4 screws from the radio. One in each corner.
Careful with the antenna. It does not just pull out, you have to pull the lock first, then the actual connector.
Old Jul 1, 2008 | 06:16 PM
HemiJay's Avatar
HemiJay
Thanks for the reply. It's an 06 though. I see the last screw on the amp behind the dash, but I would need a special wrench, (from what I can figure out), to get to it. I finally said forget it and replaced the head unit. I wish I would have seen your response before I pulled the antenna wire though....Yeah, it's not in the best shape anymore...
