2008 differential opinion
Old Jul 4, 2008 | 12:00 AM
ironbyron's Avatar
ironbyron
Default 2008 differential opinion
Hi,I recently purchased my first Dodge.It's a2008 1500 SLTRam 4 wheel drive.I now have realized after purchase that the rear end is open, not anti slip.I would like to change it over to a posi.Any opinions on the Richmond Powertrax ,Detroitlocker etc.I was a previousFord truck owner and everydifferential I had was always limited slip.I missed that one on purchase.I drive 90% Hwy dry,snow, ice etc.......Regards,
Old Jul 4, 2008 | 12:11 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default RE: 2008 differential opinion
You're better off...the factory LSD is a turd. I'd go with a Auburn or Eaton if it was me...in that order. What gearing did you get?
Old Jul 4, 2008 | 12:21 AM
ironbyron's Avatar
ironbyron
Thanks for your reply........3.92
Old Jul 4, 2008 | 02:36 AM
HammerZ71's Avatar
HammerZ71
I have the Auburn Gear LSD, works great. Locks up great when you need it and don't know it's there when you don't...
Old Jul 4, 2008 | 02:33 PM
ironbyron's Avatar
ironbyron
Thank you.........Auburn LSD is the direction I'm heading in. Regards,Ironbyron
Old Jul 10, 2008 | 05:58 PM
antelope's Avatar
antelope
I made the same mistake and bought one with 3.92s and an open differental. After 35k miles of tires spinning through 3rd gear, I bought a Detroit Locker TruTrac and couldn't be happier with it. I can only break the tires loose when I try. I have had the new diff for about 8k miles and no problems yet. Decided to go with the Detroit because it is a clutchless system unlike the Stock, Auburn, and many others. With the 33s that come with the Ram's is right about at the limit of clutch baised rear-ends capability
Old Jul 10, 2008 | 07:53 PM
ironbyron's Avatar
ironbyron
Good info, thanks for the reply, Regards,Ironbyron
