Door lock question
Old Jul 8, 2008 | 03:29 PM
Ironhead's Avatar
Ironhead
Default Door lock question
Have an 08 SLT QC. Is there a way to program the locks so they all unlock with one press of the remote, or better yet have all the doors unlock when you turn off the ignition.
Old Jul 8, 2008 | 04:20 PM
07 Ram TRX4's Avatar
07 Ram TRX4
Default RE: Door lock question
Well... there should be a way to use the remote to do the single click... you'll have to read the Owners Manual... or maybe someone else will give you the steps... Fairly easy... I don't know about unlocking when you turn the ignition off.. My 07 unlocks the door when one door opens... and besides... can't you just push the unlock button when you shut it off?
Old Jul 8, 2008 | 07:25 PM
chromeladyracing's Avatar
chromeladyracing
I tried the manual settings, never could get it to work. I have found that the dealer needs to use computer to change any of the remote settings. I cant stand the horn when locking doors.........I will stop at dealer next time Im close by.
Old Jul 8, 2008 | 09:59 PM
PhotoRam's Avatar
PhotoRam
The dealer doesn't have to change anything. It worked on my 08 the first time I tried the directions in the users manual.
Old Jul 9, 2008 | 02:59 AM
lxman1's Avatar
lxman1
Site Moderator
Yep, mine was already that way as far as when I turn off the truck and open the door, all 4 unlock. It is in the owners manual how to program that function.
As far as one touch remote, I've never seen a truck that did that. My 01 Ford never did either. Once for drivers door and again for the rest. My 07 Grand Caravan unlocks all with one push.
Old Jul 10, 2008 | 09:14 AM
Ironhead's Avatar
Ironhead
I tried to program the locks per the manual about a month ago and had no luck. Desided to try it again yesterday and it worked on the first try - go figure. Now all the doors unlock when I open one. Also saw in the manual where you can program all the doors to unlock with one press of the remote but I haven't tried it yet.
Old Jul 10, 2008 | 10:33 AM
rayk3's Avatar
rayk3
Someone on this site or one of the other forums posted the instructions to do exactly that. My remote is programmed that I push the button once and all 4 locks open. I did have to perform the instructions twice for it to work.
Old Jul 10, 2008 | 11:44 AM
Parts/Service's Avatar
Parts/Service
Hope this helps.....
RKE TRANSMITTER CUSTOMER PREFERENCES AUTOMATIC (ROLLING) LOCKS The rolling locks feature can be toggled ON/OFF by using a scan tool only.
HORN CHIRP DISABLING / ENABLING The horn chirp can be toggled using a scan or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the horn chirp feature: 1. Enter the vehicle and close all doors. 2. Fasten the seat belt (this will cancel the seat belt chime). 3. Turn the ignition to the ON position. 4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the UNLOCK button. When a single chime is heard, release both buttons. 5. Turn the ignition OFF. 6. Turn the ignition ON or wait 60 seconds. 7. Test the horn chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the horn chirp feature, repeat the above procedure.
OPTICAL CHIRP (FLASH) DISABLING / ENABLING The optical chirp can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To DISABLE (cancel) the optical chirp feature: 1. Enter the vehicle and close all doors. 2. Fasten the seat belt (this will cancel the seat belt chime). 3. Turn the ignition to the ON position. 4. Press and hold the LOCK button for 4 seconds. Within 6 seconds with the LOCK button still depressed, press the PANIC button. When a single chime is heard, release both buttons. 5. Turn the ignition OFF. 6. Turn the ignition ON or wait 60 seconds. 7. Test the optical chirp feature by pressing the LOCK button. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To ENABLE the optical chirp feature, repeat the above procedure.
UNLOCK SEQUENCE The unlock sequence can be toggled using a scan tool or by using the Remote Keyless Entry (RKE) transmitter that is already programmed to the vehicle. To toggle between Driver door first and Unlock all doors function: 1. Enter the vehicle and close all doors. 2. Fasten the seat belt (this will cancel the seat belt chime). 3. Turn the ignition to the ON position. 4. Press and hold the UNLOCK button for 4 seconds. Within 6 seconds with the UNLOCK button still depressed, press the LOCK button. When a single chime is heard, release both buttons. 5. Turn the ignition OFF. 6. Turn the ignition ON or wait 60 seconds. If a chime is not heard, program mode was canceled before the feature could be disabled. If necessary, repeat the procedure. To toggle this feature, repeat the above procedure.
