4.7 overheating
Old Jul 14, 2008 | 08:36 AM
haf2race's Avatar
haf2race
Default 4.7 overheating
I've got a 4.7 Quad that I pull a 8x16 enclosed trailer (about 5000 lbs). It has a 180 thermostat and runs cool when not pulling trailer. It doesn't get hot when pulling the trailer unless the A/C is on. The gauge is about a 1/8inch over the half way mark with the A/C on only. If I cut the A/C off it goes to half way on gauge. I don't like running that high with the aluminum head problems. Anybody elsehave this problem? Is this anything to worry about?
Old Jul 14, 2008 | 07:30 PM
lxman1's Avatar
lxman1
Site Moderator
Default RE: 4.7 overheating
If it is in the normal range, don't worry about it. It's normal to run a bit hotter when towing and running the a/c, etc. It's probably only running about 220 which is ok.
