shifting from reverse to drive clunking
Old Jul 21, 2008 | 08:29 PM
big_chops's Avatar
big_chops
Default shifting from reverse to drive clunking
making a loud clunk/sounding like something snapping. when i rotate the drive shaft with a wrench it makes a similar noise but not as lound comming from the rear end. any clues. i replaced the read ds u joint when i first got it, and i thought it was maybe the front ds u joint but i further inspected to find this. any help is greatly appreciated.
Old Jul 21, 2008 | 08:40 PM
big_chops's Avatar
big_chops
Default RE: shifting from reverse to drive clunking
there is some play in the shaft when i tried moving it by hand. also between 45 and 60 mph there is vibration comming from the rear of the truck.i replaced the diff fluid when i did the one u joint and found a small chunk but that was over a year ago and it ran fine until now. hopefully its nothing major, i cant even afford the lift and tires i want. college is eating all of my money
Old Jul 21, 2008 | 09:12 PM
sos's Avatar
sos
Do you have the limited slip differential? I've seen a lot of people on here talk about problems with that breaking.
Old Jul 21, 2008 | 09:14 PM
CarGuyOhio's Avatar
CarGuyOhio
Some drive shaft play is normal.
When you shift from R to D are you stopped or still rolling?
CarGuyOhio's Avatar
CarGuyOhio
Oh, and you found a chunk of what and where?
Old Jul 21, 2008 | 09:27 PM
big_chops's Avatar
big_chops
yes on the lsd. and im stopped when i shift. i can hold my foot on the brake and go in to D then R then D and when i put it in D i hear it. and it was like a half moon looking thing of metal.
Old Jul 22, 2008 | 08:08 AM
CarGuyOhio's Avatar
CarGuyOhio
C clip. Take your truck in for differential service, hopefully it is not to late.
Old Jul 22, 2008 | 08:09 AM
CarGuyOhio's Avatar
CarGuyOhio
By they way, if your truck is a 02-05 and has less than 70K it should be covered under warranty.
Old Jul 22, 2008 | 08:37 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
ORIGINAL: 94rt10ohio
****, another one bites it. don't drive that thing around without taking a look at that diff first!! you might have caught it soon enough, don't ruin it.
Old Jul 22, 2008 | 10:35 AM
big_chops's Avatar
big_chops
ha i can barely afford to eat, im going to have to driveit because work is not within bike riding distance
