3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Will changing the oil from 5W-20 to 5W-30 damage the engine with MDS? I read on the internet that if you put in any oil heavier than 5W-20 will shut the MDS off. I just wanted to know if there is any truth to this. Thanks
I've seen this mentioned several times here, and the caution was always to stay with the 5W20...so I do. It's my understanding that using the heavier oil will affect the MDS adversely.
Maybe this is where the theory comes from, but I cant imagine the switch in oil alone would trick the engine into shutting off MDS. I would think a setting in the computer would also have to change. In any case, I am sticking with the manual and using 5W-20.
