E3 spark plugs
Old Jul 25, 2008 | 10:18 PM
mmstar23's Avatar
mmstar23
Default E3 spark plugs
anyone have any input on them? not so concerned with fuel mileage, but more so some performance. right now NGK copper is in it. just figured i would try them out and since i have nothing to do tomorrow i would put them in. oh and just in case any of you dont know, its an 02 4.7
Old Aug 9, 2008 | 10:23 PM
timm667's Avatar
timm667
Junior Member
ready to take mine out
seemed run good at first but after a couple months I'm taking them out
power is down, mileage is down.
guess the real test is to see what happens when i change back
i have a 2001 QC 4.7
Old Aug 10, 2008 | 12:38 PM
Heminator2's Avatar
Heminator2
My next plug change will be the NGK Iridium plugs. I have the NGK 5306 plugs now and like their performance, however, they will not last as long as the Iridium plugs.
Old Aug 22, 2008 | 03:32 PM
mmstar23's Avatar
mmstar23
well i have been running the E3's for about a month now. and they suck! the idle isnt bad always, but sometimes ill be sitting at a stop light and the rpms drop to 500 and the truck starts to vibrate. give it some gas and it goes back up to about 650.
im changing them back to NGK. my only question is should i get the iridium laser cut ones? or should i get the regualr copper NGK? price doesnt matter, i just want to know whats the better plug for this truck
Old Aug 29, 2008 | 10:07 PM
MAX15004's Avatar
MAX15004
New Member
I Goggled NGK SPARK PLUGS, and searched parts for my 04 1500 4.7 and found.
V-Power part# G-Power part# Laser Platinum part# Iridium IX PART# My questions is What type should I use. My 4.7 is still stock with a KN filter change in the original compartment. Also Denso also kept coming up during my search. Is this also a Good Plug in regards to Iridium?
Old Aug 30, 2008 | 02:55 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
glad to hear the 5306 worked well for you. got a set waiting for me to gte my legs workin again, along with shorty spark plug wires.
Old Aug 30, 2008 | 06:27 AM
HankL's Avatar
HankL
Before 'judging' a new spark plug
sharpen all the edges on the OEM plugs
re-gap them
index them so the 'ground posts'
both face outward
so that the 'flame kernel' can grow nearly all directions
without having this post 'shield'
some part of the combustion chamber.
http://www.moparmusclemagazine.com/t.../photo_03.html
with two sparkplugs per chamber
what are the chances that some new plug design
is going to give great gains?
....small
Old Aug 30, 2008 | 06:54 AM
xfeejayx's Avatar
xfeejayx
mmstar has the older 4.7, that only had one plug per cylinder i thought.
Old Aug 30, 2008 | 07:27 AM
adavery's Avatar
adavery
You are correct, HankL's information is about a Hemi. However, FYI the new 4.7 ('08) also has 2 plugs per cylinder.
Old Aug 31, 2008 | 12:03 AM
mmstar23's Avatar
mmstar23
ok ok. Mine only has 8 plugs but that's not the question. My question is are iridiumcs better than the coppers?
