cams
ok ive been thinking of putting a 6.1 cam in my 05 ram hemiand ive been asking around what you have to do but no one can give me a straight answer some say just put the cam in and i will be fine others say im going to have to change the stroke in my 5.7and put new heads and program the pcm to the 6.1 cam so if any one has done this to there 5.7 hemi please tell me what did you did cause im even more confuse now more then ever
6.1 is a good mid to high rpm, moderate HP cam. You'll sacrifice some low end torque for the HP gains however. A good, low cost upgrade for a regular cab 4x2. My personal opinion is that in a weighty quad cab or 4x4, you are better off with the stock cam or another choice such as a Comp 260 or KRC 210 for the better low end torque gains.
The good thing about the 6.1 cam is that it doesn't NEED any other upgrades. It will work fine with the stock PCM and although I'd recommend stronger springs & retainers, a good many people have not replaced them and have no problems. Unlike Manley or Comp springs and retainers, Mopar 6.1s are very inexpensive, however, and I'd suggest you change to them with that cam...
I am wanting to put in a comp cam 268, is this possible. If so what else will have to be changed out. I want my truck to have that hard rough idle and sound like a suped up muscle car and shake the ground a little. Is this possible to do? Will the MDS still work and what will it do to the MPG?
Your gonna have to find someone with an 06+ truck with MDS or contact Comp directly on this. I know that KRC Performance has a line of CAMS for non-MDS Hemi's and a separate line for MDS trucks. The MDS versions don't spec near as good (performance wise) as the regular cams for some reason. They also offer a kit to make your Hemi non-MDS.
