neutral safety switch
Old Jul 30, 2008 | 10:06 AM
jager's Avatar
jager
Default neutral safety switch
[:@]So the neutral safety switch isn't working on my manual
You cant start it unless the clutch is pressed in right? well, my
truck starts intermittently, maybe 50% of the time it starts.
When it doesn't start I've got to reach down under the dash
behind the clutch peddle and press the switch manually.
Its mounted on a rod on the back side of the clutch and its supposed
to be fixed to the back side of the peddle. Well mine is just
floating along that rod from the clutch peddle to the fire wall.
Of course it happens right before I go camping!
Old Jul 30, 2008 | 11:48 AM
Horseapple II's Avatar
Horseapple II
Junior Member
Default RE: neutral safety switch
Thats a bummer! Wrap some tape around it to keep it activated untill you get a new switch.
