Tranny and Diff
Old Jul 31, 2008 | 09:38 PM
MikeHTally's Avatar
MikeHTally
Default RE: Tranny and Diff
If your truck is an '05, it doesn't have MDS, so 5w-20 may be a bit thin. Auto Zone "don't know diddly".
MeanHemi22's Avatar
MeanHemi22
Thats true sos... which is kind of why I wanted to change at least the diff (because of the known C-Clip problem)
And Mike, thanks for the approx values. I plan on taking it in to get the tranny fluid swapped because I hear it can be kinda hard. However, I want to do the diff myself.
Old Jul 31, 2008 | 09:40 PM
MeanHemi22's Avatar
MeanHemi22
Yes it is a 2005. My manual says 5w30 for the 3.7L and 4.7L, but 5w20 for the 5.7L
Old Jul 31, 2008 | 09:44 PM
MikeHTally's Avatar
MikeHTally
The shop manual on an '05 specifies 5w-30. The rear diff is shown to be 72 oz of synthetic, plus the four oz of friction modifier.
Old Jul 31, 2008 | 09:50 PM
MikeHTally's Avatar
MikeHTally
You can save as much as a c-note changing the tranny fluid yourself. It isn't hard, just messy. Get a pan gasket, eight quarts of fluid, and the flat filter. You'll need a catch pan, and a lot of newspaper. A torque wrench is almost a must.
Old Jul 31, 2008 | 10:25 PM
MeanHemi22's Avatar
MeanHemi22
Thanks for the info Mike. I will talk to my father about possibly helping me with it, as I would have to use all his tools if I tried to do it.
Old Aug 7, 2008 | 10:37 PM
swinger525's Avatar
swinger525
Ha, it all depends what you plan on doing. If you do a proper pump/flush, my tranny took 20 litres to completely replace the fluid.
The 7 quarts listed above only freshens up the tired fluid with some new stuff. It holds more than that.
If u use RP in the rear, you don't need no friction modifier.....But otherwise, its the whole little MOPAR bottle, I can't remember the volume of the bottle, but I could check my manual if you really need it. I know I read it somewhere in there.
Also, 5w20 is recommended by the dealers here in Ontario. I have an 04 1500QC HEMI
Old Aug 14, 2008 | 04:43 PM
BlueDodge's Avatar
BlueDodge
I believe the friction modifier is 3oz.
Old Aug 14, 2008 | 07:43 PM
MikeHTally's Avatar
MikeHTally
Might vary by year, but
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
Old Aug 15, 2008 | 10:57 PM
Earl73's Avatar
Earl73
Default diff fluid interval
Don't know if it's the same with your 05 vs. my 07, but the heavy service schedule (I have to follow it because I tow almost every day) says to change diff fluids every 15k. I THINK it's twice that if you use your truck lightly. Either way, you're due to change the diff now.
