Need Help: how ro program keyless entry remote? 2005 ram
Old Aug 4, 2008 | 02:45 PM
nutritionluke's Avatar
nutritionluke
Default Need Help: how ro program keyless entry remote? 2005 ram
I have a 2005 dodge ram hemi
a button fell off on my keyless entry remote. I purchased a new one but can not find the instructions online how to program the new remote. I matched the model/fcc ID number.
thank you,
Old Aug 10, 2008 | 11:02 PM
HemiLonestar's Avatar
HemiLonestar
Did you look in your owner's manual?
Old Aug 11, 2008 | 12:21 AM
jstmahoney's Avatar
jstmahoney
Check your owner's manual. It's in there.
Old Aug 11, 2008 | 12:22 AM
jstmahoney's Avatar
jstmahoney
OR you can just pop open the old remote, take the green chip out and put it in the new remote
Old Aug 11, 2008 | 10:54 AM
Parts/Service's Avatar
Parts/Service
The following procedure can be used as long as one programmed transmitter is available:
NOTE: When entering program mode using that programmed fob, ALL currently programmed fobs will be erased and they will have to be reprogrammed for the vehicle. If program mode is entered and no action is performed, the previously programmed fobs will continue to function.
Enter the vehicle and close all doors.
Fasten the seat belt (this will cancel the seat belt chime). Turn the ignition to the RUN position.
Press and hold the UNLOCK button on a programmed transmitter for 4 to 10 seconds. Within the 4 to 10 seconds with the UNLOCK button still depressed, press the PANIC button for one second. When a single chime is heard, release both buttons.The chime indicates the system is in program mode.
Press and release both the LOCK and UNLOCK buttons simultaneously on a fob to be programmed. A single chime will be heard, this indicates the fob has been recognized.
Press and release any button on the same fob. A single chime will be heard, this indicates the fob has been programmed.
Repeat steps 4 and 5 for up to a total of 4 fobs.
Turn the ignition OFF.
Turn the ignition ON or wait 60 seconds.
The vehicle will remain in program mode for up to 60 seconds from when the original chime (step 3) was heard. After 60 seconds, all programmed transmitters will function normally.
