Removing 2003 quad cab kick panels
Old Aug 6, 2008 | 10:32 PM
Mancunian's Avatar
Mancunian
Default Removing 2003 quad cab kick panels
I am running wires from my new head unit to the XM receiver I will install under the rear seat. Can someone tell me how to remove the plastic panels that run from by the glovebox, along the drivers door opening to the back door opening? I figure they must pry out but if I know where the clips are I stand a better chance of removing them without damage
Steve
Old Aug 6, 2008 | 10:50 PM
FFMedic1479's Avatar
FFMedic1479
First, to pull off the kick pannel you need to pull straight out from the wall (bottom of the "A" pillar). I found this easier after pulling the trim piece that is along the door opening from the "A" pillar to the "B" pillar. Maybe just because it was one thing I did not have to look at. To do this, just pull straight up. I never have been able to successfully pull the covering off the B pillar. I always feel like I will break it. But if you are running the attenna for the XM, don't bother pulling off the kick pannel or the trim on the b pillar, you can just feed it down from the top and pull your running end through the bottom (actually easier to go from the back of the truck forward). You only need to pull up the trim pieces along the floor to hide the wire and keep it protected. If you are looking to feed the attenna through your third breaklight (which I did) make sure you silicone the crap out of it so it doesn't leak (I made the mistake of going light on the silicone my first try). Good luck.
