Programmer
Old Aug 8, 2008 | 07:08 PM
minker3k's Avatar
minker3k
Default Programmer
Im lookin to buy a programmer to offset the weight and drag on my engine due to larger tires and rims, and i was wondering which programmer offers the best fuel economy along with the best power gains. I think the best one is the superchips flashpaq, and advice?
Old Aug 8, 2008 | 07:26 PM
HammerZ71's Avatar
HammerZ71
A programmer is a good idea and the Superchips would be probably the best choice for your setup, it has some decent gains and really firms up the tranny shifts, however it won't do a whole lot for the "weight drag" of larger tires & wheels.
The single best upgrade you can make to get the power to the rear wheels would be a gear swap. If you are really feeling the sluggishness from just 33" tires, my guess is you probably have the lesser desirable 3.55 gears. An upgrade to at least 4.10 or even better 4.56 gears will give you acceleration off the line and for passing that will feel night/day over what you have now...
Old Aug 8, 2008 | 07:47 PM
chefred112's Avatar
chefred112
with the tires you have I'd go straight to 4.56 gears (and the superchips 3815)
Old Aug 8, 2008 | 09:01 PM
minker3k's Avatar
minker3k
I like the edge programmer a lot, but a friend of mine told me that it would void my warranty, granted this friend is a little on the dumb side, but before i order anything i would like to know if they willvoid my warranty
Old Sep 24, 2008 | 01:28 PM
ecooley's Avatar
ecooley
Default Void Warranty
I was told by a Dodge Dealer that if something go's wrong with your engine it will void the warranty if any type of PMT is installed. Just broke a exhaust valve on my 2003 with 57K on it and Dodge Replace the engine with a new one. Glad I did not install a PMT on it now.
Old Sep 24, 2008 | 01:59 PM
RubberFrog's Avatar
RubberFrog
That's rediculous. Just program it back to stock before you go in...
Old Sep 25, 2008 | 10:18 AM
ecooley's Avatar
ecooley
Exclamation Void Warranty
Not that easy when you are broken down on the road and have to be towed to the closes Dodge Dealer. Just something to think about before you install a PMT . Check with your dealer First.
Old Sep 25, 2008 | 11:19 AM
dodgeguy97's Avatar
dodgeguy97
i would go with 4.10 or 4.27 i'm running 34x11x16 and 4.10 i get decent gas milage and when turning 55 to 60 my rpms are 2200 to 2400 just my opinion
