Hid lights help please
Old Aug 16, 2008 | 06:33 PM
dbryant51's Avatar
dbryant51
Junior Member
Default Hid lights help please
Ok so i bought new 10000k hid lights and they are all hooked up fine as far as i know, so i turn them on when the truck is off and they work great but then when i start the truck and put it into drive they kinda flicker like annoying flicker constantly and when i turn the head lights to the night time setting they flash 3 times and turn off but when i hit my hi beams they work just fine does anyone think i need a resistor or by pass a sensor or what cause they work fine when the truck is off
Old Aug 16, 2008 | 09:25 PM
RaiderJay6's Avatar
RaiderJay6
The computer cant see the light so it tests them by sending pulses to them making them flash. You need a resistor to make them work right.
Check this thread and contact Tim from Maxvision.
https://dodgeforum.com/forum/3rd-gen-ram-tech/139765-bi-xenon-hid-problem.html
Old Aug 16, 2008 | 09:51 PM
kicker417's Avatar
kicker417
ok this is wat you do you get the realy get power and ground from the battery and put it to the relay you get an input from the positive runnin to the lights and put it to the relay and then put the negative out to the lights it should work this is how i have it in my truck and they work fine.
Old Aug 16, 2008 | 11:56 PM
dbryant51's Avatar
dbryant51
Junior Member
what that made no sense explain better im kinda a newb haha
