04 Ram 1500 AWD Problems.
Hey my Ram died while i was driving down the Highway, I had most of the error codes cleared out, only two remain.
The Transmission Module and the Density Senor, both come up as failures and I can not get the truck to start.
Any suggestions? does anyone know of a RQ on these two things?
The truck can't run without a signal from the pressure (density) sensor. That's the only way it has to determine airflow and thus the amount of fuel to spray.
No signal from the transmission module is a bad sign too. At the very least it means if you get it to run you won't be driving it anywhere. Also, I thought the engine and transmission were controlled by the same computer on 04+ models. Only the 03 has a separate module.
