sloshing water sound when running ac
Old Aug 19, 2008 | 09:16 AM
ghc37's Avatar
ghc37
Default sloshing water sound when running ac
Hello, I have a 2002 dodge ram 1500 quad cab. i have noticed last week that I can hear a sloshing water sound when I run ac and turn curve or come to stop, etc. I notice there is no water draining on pavement/carport after I park it. I assume something is stopped up? How would I go about fixing this problem? Thanks
Old Aug 31, 2008 | 07:53 AM
popps68's Avatar
popps68
Thumbs up
ghc37
Look under the front near the evap. around the a/c unit you should find a drain discharge tube or maybe even a small hole of some sort, you should be able to get a small piece of wire maybe the thickness of a coathanger up inside it and just work it up and down in the tube you should see some water come out then, they get stopped up from time to time
