Just a couple questions
Old Aug 20, 2008 | 03:29 PM
rjvems23's Avatar
rjvems23
Default Just a couple questions
Hey guys im pretty new to this forum i just recently purchased a 2006 dodge ram 1500 quad cab sport. there is few things about it im not quite sure of. I have owned chevys usally and decieded on a dodge this time. But i have been reading some of the threads and wonding about some more information on this MDS and what it does exactly. I have put a KN CAI on and i all so have flowmaster 50 delta series dual exhaust on it. Im just curious if there is better muffler for this truck due to the fact when ur just crusing around it kinda sounds like crap and i would assume its due to the shift from 8 cylinders to 4 but i wasnt sure if there was a better exhaust system to eliminate this. Also im looking at getting a leveling kit to bring the nose up a little. I just want it to sit even with the rear. I have noticed there are many different sizeds such as 1in, 1 1/2 in and even 2in which would best level the truck out???? thanks for the imput
Old Aug 20, 2008 | 03:41 PM
HammerZ71's Avatar
HammerZ71
As far as the MDS with an exhaust goes it is the #1 complaint on every forum I'm on or have ever been on that has anything to do with Dodge and/or Dodge trucks. Not the performance of the system which seems to work pretty well (although I for one wouldn't have it, not that I think it's flawed or anything, but I bought an 8 cyl. truck (an '04 without MDS) and I want my 8 cylinders all the time, thank you very much). I don't know if anyone has found the perfect solution (without using resonator(s) which of course, defeats the purpose. I'm sure some of the 06+ (MDS) crowd will chime in.
As far as lift goes, you have a coil over front suspension (all 4x2s and '06+ 4x4's do) and as such, simple coil spacers are a decent, economical choice. I've found that perfectly level is about a 2.25" lift, so I'd go with the 2" spacers...
Old Aug 20, 2008 | 08:22 PM
RaiderJay6's Avatar
RaiderJay6
When driving around town if you keep it in tow/haul the MDS wont kick in. I went with the Corsa exhaust system and its not as bad when the MDS kicks in as alot of the systems out there. I use the tow/haul in the city.
Old Aug 20, 2008 | 08:40 PM
boomer79's Avatar
boomer79
Is there any drawbacks with driving around town in tow/haul mode?
Old Aug 20, 2008 | 10:11 PM
CarGuyOhio's Avatar
CarGuyOhio
Only draw back, higher RPMs which means less MPGs
I would guess Flowmaster would be one of the worst systems for MDS as it is one of the loudest.
Wonder how the Hybrid Hemi will sound?????
Old Aug 21, 2008 | 10:25 PM
rjvems23's Avatar
rjvems23
when you say it would affect mpg. How much would it affect it. and is there any other draw backs to leavin it in tow/haul mode????
