Fluids
Old Aug 21, 2008 | 11:57 PM
FFMedic1479's Avatar
FFMedic1479
Default Fluids
I wanted to change the fluid in my front and rear pumpkins to synthetic but couldn't find the amount needed in the owners manual or chilton's. Anyone know how much I need? Also, I was going to do the tranny while I was under there. I bought the Mobil 1 synthetic but it only says ATF on it but the manual calls for ATF +4. I never had a truck long enough before to warrent a tranny fluid change and don't want to put the wrong stuff in... am I ok?
Old Aug 22, 2008 | 04:10 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
from amsoil.com:
2005 DODGE TRUCKS RAM 2500 HD PICKUP 5.7L 8-cyl Engine Code [D]
NGK PLUGS & WIRE SETS
Plug.................IXIRIDIUMLZTR4AIX-11NGK2313[1]
Plug.................VPOWERLZTR4A-11NGK5306[2]
Wire Set..........WIRESETCPB-CR004NGK58918[3]
Wire Set..........WIRESETRC-CRX056NGK53020[4]
1.Twin Spark
2.Twin Spark
3.8 Coil Pack Boots required
4.8 Lead Set
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0W-30 Synthetic Signature Series Oil
All Temps......5W-20
Manual Transmission,TREMEC T56.....GL-4
75W-85[1]
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Manual Transmission,G56.....AP4
Synthetic Automatic Transmission Fluid
Manual Transmission,NV5600.....GLS[2]
AMSOIL Synthetic Synchromesh Transmission Fluid
Manual Transmission,Getrag 238.....AP4
Manual Transmission,NV4500.....GL-4
75W-85[3]
Automatic Transmission,48RE.....AP4
Automatic Transmission,545RFE 2WD.....AP4
Automatic Transmission,545RFE 4WD.....AP4
Differential, Front 9.25 AA.....GL-5[4]
All Temps......75W-90
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Severe Gear 75W-110
Differential, Rear 10.5 AA.....GL-5[4]
Severe Gear 75W-90
Severe Gear 75W-110
Differential, Rear 11.5 AA.....GL-5[4]
Severe Gear 75W-90
Severe Gear 75W-110
Standard Differential, Rear 9.25.....GL-5[4]
All Temps......75W-140
Severe Gear 75W-140
SAE 80W-140 Synthetic Gear Lube
Controlled Slip Differential, Rear 9.25.....GL-5*[4][5]
Severe Gear 75W-140
Transfer Case,.....AP4
Fluids
Power Steering Fluid.....AP4
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. GL-4 synthetic gear oil, Mopar part no. 4874459
or Castrol Syntorq are recommended.
2. GLS is a special gear lube, Mopar part no. 04874464.
3. GL-4 synthetic gear oil, Mopar part no. 4874459
4. Synthetic based oil.
5. Trac-lok equipped axles require Limited Slip Additive be
added to the lubricant
CHASSIS LUBRICATION
Two-wheel drive
6-9 Fittings, 0 Plugs..........LB
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
Four-wheel drive
5-11 Fittings, 0 Plugs..........LB
CAPACITIES
Engine, with filter..........7.0 quarts[1]
Cooling System, Initial Fill..........16.0 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 48RE Initial Fill..........4.0 quarts[2]
Automatic Transmission, 545RFE 2WD Initial Fill..........5.5 quarts[2]
Automatic Transmission, 545RFE 4WD Initial Fill..........6.6 quarts[2]
Automatic Transmission, Total Fill
5 speed 545RFE 2WD..........17.0 quarts
5 speed 545RFE 4WD..........17.0 quarts
4 speed 48RE..........17.0 quarts
Manual Transmission, NV4500..........8.0 pints
Manual Transmission, NV5600..........9.5 pints
Manual Transmission, Getrag 238..........4.6 pints
Manual Transmission, T-56..........4.6 pints
Manual Transmission, G56..........9.9 pints
Differential, with 11.50 ring gear Rear..........7.6 pints[3]
Differential, with 10.50 ring gear Rear..........5.3 pints[4]
Differential, with 9.25 ring gear Rear..........4.4 pints[5]
Differential, with Dana 60 Rear..........5.9 pints[6]
Differential, with 9.25"AA Front..........4.9 pints[6]
Transfer Case,NV271..........4.0 pints
Transfer Case,NV273..........4.0 pints
Transfer Case,NV241 GENII..........3.4 pints
Transfer Case,NV243..........3.4 pints
Transfer Case,NV244 GENII..........3.4 pints
1. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
3. Fill no higher then 1/4" below plug hole.
4. Fill no higher then 3/4" below plug hole.
5. Fill no higher then 5/8" below plug hole.
6. Fill no higher then 1/4" below plug hole.
TORQUES
Oil Drain Plug.....25 ft-lbs
Transfer case
Fill Plug.....15-25 ft-lbs
Drain Plug.....15-25 ft-lbs
Manual Transmission NV5600 6-SPD
Fill Plug.....22 ft-lbs
Drain Plug.....30 ft-lbs
Manual Transmission NV4500
Fill Plug.....25-35 ft-lbs
Drain Plug.....25-35 ft-lbs
Manual Transmission Getrag 238
Manual Transmission G56
Fill Plug.....42 ft-lbs
Drain Plug.....42 ft-lbs
Manual Transmission T56
Fill Plug.....20 ft-lbs
Drain Plug.....28 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
OTHER TOP QUALITY PRODUCTS
Mothers® Car Care Appearance Products
By-Pass Oil Filters
Old Aug 22, 2008 | 04:12 AM
xfeejayx's Avatar
xfeejayx
remember, 2 pints=1 quart
Old Aug 22, 2008 | 09:02 AM
FFMedic1479
Holy crap... thanks!
Old Aug 22, 2008 | 10:05 AM
xfeejayx's Avatar
xfeejayx
you're welcome.
just noticed it says 100% synthetic 0w-20 for engine oil, that ain't right.
Old Aug 22, 2008 | 11:18 AM
FFMedic1479
Why does it call for iridium plugs... thought champions were the stockers
