I thought the 4.7 was revised this year???
Old Nov 9, 2007 | 11:24 PM
Ben D.'s Avatar
Ben D.
Default I thought the 4.7 was revised this year???
just looked at dodge website and for the 08's the specs of the 4.7 are still the same 235hp-300lbft. I thought it was going up to 295 hp and 310 lbft of torque for 2008. is this an error at dodge.com or did the revision not happen?
Old Nov 10, 2007 | 12:02 AM
NYPANAMA42's Avatar
NYPANAMA42
Default RE: I thought the 4.7 was revised this year???
Where did you get your numbers from? I heard it was going to be 375HP and 400Lbs of torque.
Old Nov 10, 2007 | 12:07 AM
Ben D.'s Avatar
Ben D.
375 400 sounds extreme for the 4.7L I mean that would beat out the hemi? I don't think dodge would do that.
Old Nov 10, 2007 | 12:45 AM
turbot_bird's Avatar
turbot_bird
in the dakotas, its 302hp
Old Nov 10, 2007 | 05:32 AM
hemiyellow's Avatar
hemiyellow
DC Insider
2009MY is when it's being changed across the board
Old Nov 10, 2007 | 07:55 AM
BanksPwrHemi's Avatar
BanksPwrHemi
2008 4.7 now has31% more power. The rating is 315hp.
Old Nov 10, 2007 | 10:41 AM
Ben D.'s Avatar
Ben D.
hemi yellow so the new 4.7 doesn't hit the market until 2009 in the ram??
Old Nov 10, 2007 | 10:47 AM
tdmopar59's Avatar
tdmopar59
sounds that way.... what are the actual specs going to be... HP and Torque?
Old Nov 10, 2007 | 11:08 AM
hemiyellow's Avatar
hemiyellow
DC Insider
ORIGINAL: Ben D.
that is correct, specs should be something like this: 290 HP, 320 Ft-lbs 9.8:1 compression, dual spark plugs per cylinder.
and i think thats about the biggest changes their making
Old Nov 10, 2007 | 11:19 AM
Max Power's Avatar
Max Power
With the lifetime warranty, I am guessing their will be all sorts of Torque Management in the factory tune that will take a while for the aftermarket to crack. Of course, at over 300hp, there is less reason to want to.
