Lumbar support broken
Old Aug 27, 2008 | 10:27 PM
LastChild69's Avatar
LastChild69
Default Lumbar support broken
OK got into truck and POP seat went flat and lumbar **** fell off, I'm not that heavy (about 200lbs.). Did some searching and I'm not the only one. Took the assembly apart ( not that hard, **** pulls off and plastic star center unscrews) and the white threaded plastic piece broke. This part pulls on a little rod to give support (it doesn't turn the rod like some thought). Pulled seat covering over the **** holder and can see the back of rod where it's attached, took needle nose and pulled towards door,that's how it makes the support. I was able to wedge a small hard rubber grommet in to hold. Only thing I can't figure out is how would you replace the white plastic piece ? It seems you have to remove the little rod and slip it back through, but I can't see how? Anyone Know ? TIA
Old Aug 27, 2008 | 11:04 PM
shoedork's Avatar
shoedork
I did the same thing like 2 weeks after i got my truck, i turned the **** to much and yea pop......no lumbar. i took it to the dealership and it was covered under the warranty, so i got it fixed no charge
Old Aug 27, 2008 | 11:21 PM
FFMedic1479's Avatar
FFMedic1479
I would look in the junkyards for a replacement... probably the same part used in all dodge trucks, dakotas, etc. and just replace it. It is made from plastic, so it probably wore out or whatever, a repair may just not do.
Old Aug 28, 2008 | 06:29 AM
HankL's Avatar
HankL
sorry to hear that it broke
these special glues work better on plastics than others:
http://www.loctiteproducts.com/produ...d=168&plid=661
http://www3.towerhobbies.com/cgi-bin...?&I=LXHU34&P=W
wrapping aluminum foil around that outside of a part is a way to reinforce it,
but do this as a secondary step after successfully gluing the plastic
Old Aug 28, 2008 | 07:11 PM
kx250frider617's Avatar
kx250frider617
wow mine 03 has a electric button you press and theres a what ever is inside the seat moves. I thought it was a airbag inj there like a semi's seats.
Old Aug 28, 2008 | 10:10 PM
LastChild69
Thanks for the advice, but replacing or repairing the plastic piece is not the problem, it's getting the white threaded part back into the small rod. The rod has to go through the plastic piece and I don't see any way to get the rod assembly apart.
Old Sep 1, 2008 | 07:39 PM
eaglestorm's Avatar
eaglestorm
lift up the seat back cove and expose the system it twists in
