Check engine light? maybe
Old Aug 29, 2008 | 12:47 PM
LegendRacer6's Avatar
LegendRacer6
Default Check engine light? maybe
I'm new to this truck 2002 Dodge Ram slt 4.7 2wd.
This morning when I left for work I had what I believe to be the check engine light come on. It was a yellow/orange outline of a engine on the left of the dash near the tach. So I pulled over checked to make sure there was oil in the engine, trans fluid and radiator coolant and all was good. I remember how to do OBD on my 93 Dakota and when I did that in the odometer area it just said dOne ... No code some -------- and then done.
So am I ok? Truck sounded normal and acted normal.
I found this thread that I will use when I get home from work. Drove the '93 Dakota to work to day glad I kept it
https://dodgeforum.com/forum/3rd-gen-ram-tech/26453-another-check-engine-light.html
Old Aug 29, 2008 | 03:29 PM
LegendRacer6
P0442 Evaporative Emission Control System Leak Detected (small leak)
Thats what I got.
Old Aug 29, 2008 | 07:19 PM
Parts/Service's Avatar
Parts/Service
Check all the rubber emission hoses under the hood and the rubber hoses going to the evap canister under the truck. The canister is on the drivers side at the front of the bed...
Old Aug 29, 2008 | 07:33 PM
rammindodge03's Avatar
rammindodge03
did you recently just get gas?
Old Aug 30, 2008 | 12:36 AM
LegendRacer6
On Monday I filled up, still pretty full.
Old Aug 30, 2008 | 12:52 AM
mmstar23's Avatar
mmstar23
legend racer...... i see what truck you have. the early ram with the 4.7. first of all, take care of this current problem, and sorry but i have no input on it specifically...however. i highly, highly recomend you do some research and get into that oil pan to do some cleaning. take it from me personally, you can read through my oil pressure thread
Old Aug 30, 2008 | 06:57 AM
NHRedRam's Avatar
NHRedRam
I had a similar problem with my 03 4.7 right after I bought it. The dealership where I bought it told me it was from filling it up while the engine was running(bad habit I had). It didn't actually throw the light until 50-60 miles after the fill up. I just brought it to them and they re-set it, No problems since then. They also mentioned the gas cap at first.
