Too Much Timing????
Old Sep 9, 2008 | 05:16 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default Too Much Timing????
So I went out last night and did some DAQ runs with my superchip. One of the criteria that I logged was timing advance. Just as some background I am running the 91 tune with 93 gas and the mods listed in my sig. Anyway, when I checked the data after I downloaded it I noticed that my timing advance was as high as 47*. This seemed like way too much to me but I was looking to get some other opinions. Also, when I run the truck with the 91 program installed, the engine pings a good bit and when I go back to stock the ping is gone. Has anyone else ever have this happen with their superchips? Any ideas as to what this could hurt if I continue to run it like this?
Old Sep 9, 2008 | 05:59 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
i would recommend taking that power wire off if you are already using the SC to advance. That might be overdoing it.
Old Sep 9, 2008 | 08:19 PM
Off_Road_Teacher
I thought of that but when I reset the truck to stock, the timing was much less advanced. It seems like the superchips is doing something weird ever since I updated it bc I never had this much timing even with the superchips and power wire in combo.
Old Sep 9, 2008 | 11:41 PM
xfeejayx's Avatar
xfeejayx
well the SC is not advancing timing when it is in stock mode. the power wire is a "dumb" way of advancing timing, you just tell the truck air is ~20* colder than it is, and that usually isn't a problem at all by itself because it isn't advancing too much.
The SC in performance mode is a smart way of advancing timing safely and should push further to your knock/ping limit, but stack on a "dumb way" and lie to your SC, which is already trying to advance the hell outta the timing, and things might be bad.
I wouldn't even have worried about it, but you'r noticing a ping, which indicates the power wire or SC advance needs to go, but the SC is a much smarter way of doing it.
