HID Help
Old Sep 10, 2008 | 10:52 PM
cmnspwr's Avatar
cmnspwr
Default HID Help
I bought a HID kit from a guy off of another forum. He hasn't been on in two days and nobody is responding to my question on the forum. I though I would try here. The relay only has one "blue" plug that I assume plugs into the factory harness. Right? Shouldn't I need two of the blue plugs, one for the driver side light, and one for the passenger side? Also am I supposed to have two grounds and one hot wire? One ground for the driver side ballast, one ground for the passenger side ballast, and one hot wire to power all of it? Is that right?
Old Sep 10, 2008 | 11:20 PM
kicker417's Avatar
kicker417
yes kinda but you can just use the same ground for both i got my ground for the battery
Old Sep 10, 2008 | 11:21 PM
cmnspwr's Avatar
cmnspwr
So do I plug the "blue plug" into only one factory harness? Or do I need two blue plugs?
Old Sep 11, 2008 | 02:14 AM
kicker417's Avatar
kicker417
well mine came with 2 but they are not all the same so i would say try it and see wat it does
Old Sep 11, 2008 | 02:29 AM
bomrat's Avatar
bomrat
you only need one blue plug, its using the plug to trigger both sides of the hid's.
i put a kit on my dakota like this and it worked great.
