4.7l performance....
Old Sep 15, 2008 | 10:14 AM
froto'sride's Avatar
froto'sride
Default 4.7l performance....
Looking for a programmer for an '04 4.7l anyone out there able to help with this? I can find it for just about everything else but this year and no i do not want that wast of money jet chip.
Also does anyone know what was changed on the '08 4.7l to pull so much power. i mean if it is just the pcm or maybe a cam that should be easy to get our hands on...
Old Sep 15, 2008 | 10:30 AM
HammerZ71's Avatar
HammerZ71
As far as a good tuner, you are out of luck until Superchips includes the '04. It's supposedly in the works, so I'd imagine it should only be a few months away.
'08 4.7 is a complete redesign, 16 plugs vs. 8, different compression ratio, better port flow,a new combustion system design and completely different piston/rod assembly. It actually more closely resembles the Hemi than your 4.7 and is commonly referred to as "the semi-hemi"...
Old Sep 16, 2008 | 10:27 AM
froto'sride
so basically a mini hemi...that makes me wonder if the block is the same because maybe those heads will fit say an '04 block and see if ya get som better flow and maybe a little better burn with the dual plugs....
Does superchips have a website or anything that might have some info on the completion or at least something that saya they are working on it?
Old Sep 16, 2008 | 10:48 AM
froto'sride
do you know of any chrysler, dodge, mopar site that may sell these heads?
Old Sep 16, 2008 | 11:55 AM
TRXHemi's Avatar
TRXHemi
I was wondering what the new 4.7 had in it that was different. I have an '08 and was surprised that it had 310hp. I have the 3.21 rear-end and the five speed auto. On a recent trip, I averaged 20.5 mpg. Not too shabby.
Old Sep 16, 2008 | 05:26 PM
froto'sride
from what i've read about them you have exactly what hammerz71 said...you have a mini hemi. the whole 4.7l design has been modified except maybe the block itself. if you look at the original design of the 4.7l, mostly the heads you will see that chrysler was leaning that direction from the begining.
