Infinity Amp Question
Old Sep 19, 2008 | 02:51 PM
daytonaramrod's Avatar
daytonaramrod
Default Infinity Amp Question
I Have a 2005 dodge ram with the infinity system, i replaced the head unit with an alpine flipout, now since i did that i lost the 3 tweeters on top of the dash and just have the front doors and rear speakers playing. I tried the metra harness with the rca ends to it but it didint work corretcly i had to sound out of them
pretty much all i want to know is does anyone have an aftermarket radio and still have there 3 tweeters on the dash playing and how they did it!!
Old Sep 19, 2008 | 03:41 PM
kx250frider617's Avatar
kx250frider617
they probably just wired the speakers to the hu. They should have got the harness that taps into the factory amp. Id say get a cheaper 4ch amp and get new speakers that fit yout budget. But take it back becuase They should do it right or not at all.
Old Sep 19, 2008 | 03:43 PM
kx250frider617
thats if a shop did it but if you did it, they sell a mopar harness that you have to tap into the factory amp wires. pretty easy but all speakers should work.
Old Sep 20, 2008 | 12:13 PM
daytonaramrod
All the harness does that i think you are thinking of is bypass the amp, which mine is how that is not, that plug plugs into the output side from the amp, so when the signal goes from radio through the plug it only still does to the regular speakers not the tweeters, unless you have done it this way then im completely wrong
Old Sep 20, 2008 | 12:56 PM
kx250frider617
Well before I added just a new hu and sub and amp and all my speakers worked including the dash speakers ut now I have a 5ch 1000w kicker amp to power my alpine type r speakers and two 500w mono alpine amps to power my 2 type r 12" subs. All this and my hu is still connected to the factory amp so my factory dash speakers still work. I haven't had the time to change them out. Maybe take it to a local stereo shop, NOT best buy or circuit city, they'll hook you up and make everything work perfect. It's no impossible becuase mine work.
