08 hard top tonneau cover issues?
Few question about tonneau covers
1. Will it help with gas mileage, I would assume it would because of the wind not catching the tailgate
2. Will it give you a little more speed, I assume it wouldc again because of no tailgate wind issues
3. 2008 trucks have that fin on the back, I have heard there is issues when you remove the fin and install a hardtop, the holes from the fin will show, true or false
4. I am only going with a hardtop and having it painted to match my truck, which model is best in your opinion
thanks
thanks
1. nope....well, maybe a bit..but not enough to notice much with thirsty hemi's, if all you did was interstate driving and kept your RPMs less than 1.8K the whole time, you might notice a difference...but nothing substantial.
2. if you get a fiberglass cover you will probably go slower just due to the added weight versus any aerodynamic gain...negligible difference again as far as "seat of your pants" noticing anything.
3. couldn't tell you about "fins" on 2008's...I have a 2008 and I don't see any fins on the bed or tailgate.
4. Leer and ARE are your best bet for color matching hard tonneau's...there are lighter aluminium models out there, but I haven't heard anything good/bad about them yet.
When I was looking at hard covers, the guy at the truck toy store that I went to said that you have to take the fin off, but there is also a part that replaces that in order to allow the hard cover to fit, which, I would assume, fits in the holes for the fin.
Hope that helps and/or makes sense.
-slide
-slide
Does it help with mileage Id have to say yes, I have seen an increase of a little over a 1.5mpg (pen and paper) but I also added gears at the same time so its hard to say exactly what just the hard cover did. For speed, maybe a higher top speed due to better aerodynamics but nothing that you will ever notice, also after adding mine you could tell the extra weight was there too. I have no clue about the 08 fin though as mines an 05'. I went with the ARE cover, the lines match up perfectly with the hoods look as well so it adds a little extra flair and comes painted to match your factory paint.
