bi xenon hid easy fix or bad fix???
Old Sep 19, 2008 | 07:47 PM
mountaingade's Avatar
mountaingade
Default bi xenon hid easy fix or bad fix???
Like many other guys here, I purchased a bi xenon hid conversion kit and had the flashing light thing like many of you, again. just for fun, I decided to add a second bulb connector on the wires of the original bulb connector so that I could use the oem one for the oem lights, and the second one for the hid's. To my suprise, it worked. Even the daytime running lights work on the hid's. The problem with this "easy fix" is that you need to leave the oem bulbs connected so that the cpu can read them. So to you guys good in electronics, is this a GOOD easy fix, or a BAD easy fix.
thanx
Old Sep 19, 2008 | 10:32 PM
RaiderJay6's Avatar
RaiderJay6
Sounds like a good fix to me.
Old Sep 19, 2008 | 10:34 PM
disturbedgator's Avatar
disturbedgator
you know what you should do is make a custom housing for the extra bulb and put them in the grille!
