HELP !!!!clicking noise still after changing lash adjusters
Old Sep 30, 2008 | 11:21 PM
deadof_knight's Avatar
deadof_knight
Default HELP !!!!clicking noise still after changing lash adjusters
Ok my drivers side bank has been clicking ....I found a few lash adjusters bad worn out or locked up so I changed them all on that bank. I have oil comming out of them and the camshaft.... I cleaned all the bores and holes does anybody have a oil schematic for a 4.7 2003 model ....maybe I have a check valve hung..... it clicks pretty heavy at startup but after a while it goes away... im stumped oil pressure shows fine all though im going to check it with a gauge. give me some Ideas please
Old Apr 23, 2010 | 08:45 AM
dxrperformance39's Avatar
dxrperformance39
well i am having the same issue after the new install and i been reading around and everyone is blaming the ticking sounds from the exhaust manifolds bolts and gaskets. I did check mine and i don't see any carbon around as a sign of leaks but i hear people solving their issue with a gasket change. As far for me i am starting to head towards my main rod bearing to make sure. If you here any thing or solved your problem let me know my email is venom3971@yahoo.com
Old Apr 23, 2010 | 10:47 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
this thread is only dated back to 08'
Old Apr 23, 2010 | 12:49 PM
RubberFrog's Avatar
RubberFrog
The Op checks this thread twice daily, still waiting for the answer.
Old Apr 23, 2010 | 01:44 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^^ lol
