Nitrogen in Tires
Old Oct 15, 2008 | 02:06 PM
  #21
Tonyo88's Avatar
Tonyo88
The biggest advantage in nitrogen is he fact that it doesn't change density as much with changes in temperature. That's why aircraft use it in their tires, they can go from 40 degrees above to 40 below in a matter of minutes. Seeing as a road vehicle won't have this problem, then there's really not much of an advantage except for season changes. And its so gradual that it's really not an issue.
Old Oct 15, 2008 | 02:07 PM
  #22
BCGray's Avatar
BCGray
A side benifit to a nitrogen fill is that Nitrogen expands less than straight air, this is crucial for us with TPM's, less checking/adjusting tire pressure on long trips and less flashing TPM lights. Just don't let "Goober" at the Tire store put those "Green Caps" on your TPM valve stems.
Old Oct 15, 2008 | 06:50 PM
  #23
thehemiman12345's Avatar
thehemiman12345
If I had a ferrari or a lambo I might fill em up with nitrogen, but.......I don't so regular old air will work for me.
Old Oct 15, 2008 | 10:01 PM
  #24
moeman's Avatar
moeman
Talking
Originally Posted by lxman1
Well, my aluminum wheels ain't gonna rust from a little moisture in the air.
I wonder if thats what made my previous dodge pickups chrome lug nut covers rot off? :^)
Anybody elses nuts rot?
Old Oct 16, 2008 | 12:30 AM
  #25
reindeerman's Avatar
reindeerman
Makes more sense with aircraft. I actually do have a Ferrari and I use metric air pressure for it. In the ram I just use good old American stuff!
