rust
Old Oct 12, 2008 | 06:24 PM
irelandshemi's Avatar
irelandshemi
Default rust
so i was just standing by my truck and noticed some little rust spots that almost seem to be raised out of the paint, like little dots, and then next to that theres a little like dime size mark were the paint is bubbled up, is there anything i can do to stop the rust from spreading, and stop that bubble from getting any bigger. thanks
Old Oct 12, 2008 | 07:19 PM
RAM_05's Avatar
RAM_05
If they are small enough you could just sand them off and hit them with some touch up paint. But if they are on the larger side it may be off a little.
Old Oct 12, 2008 | 11:09 PM
irelandshemi
i dont mind so much it being off but i just dont want it to spread, so would i sand that paint bubble off and then touch it up
Old Oct 13, 2008 | 01:32 AM
Ben D.'s Avatar
Ben D.
on the little rust spots try a claybar. sometimes they arn't so much rust as metal particles embedded in the paint that then rusted but are in reality just sitting on top of the paint. ie. rail dust on newer cars. but for teh bubble... take it to a body shop see what they say. better to fork out maybe a few hundred on a repair now than a few thousand later when it spreads.
Old Oct 13, 2008 | 08:51 PM
irelandshemi
mm ill try the claybar, and then when i get time take it to my friends shop
Old Oct 13, 2008 | 09:03 PM
RAM_05's Avatar
RAM_05
I would just take it to your friend's shop. If it started as a rust spot and and is now beginning to bubble I just don't see how a clay bar is going to help.
Old Oct 13, 2008 | 11:01 PM
Ben D.'s Avatar
Ben D.
metallic particles can become imbedded in the paint that normal washing will not remove. these are just plain old metal not painted and such and will rust obvioulsy. this will make certain odd brown dots on the paint like the OP described. at first glance it freaks you out because you think rust but in reality it is just a metallic particle stuck on top of the paint and a claybar will remove all contaminants on the paint and if that is what is going on with the OP's vehicle then it should remove the brown dots. if it acutally is the paint rusting then no.
Old Oct 14, 2008 | 09:44 AM
RAM_05's Avatar
RAM_05
I guess I should have been a little more clear. I understand what you meant, but the way he describes them it makes me think that they were rust spots and are now bubbling under the paint.
Old Oct 19, 2008 | 05:20 PM
irelandshemi
i guess im gunna have to, yeah the little rust spots are brown almost dots with an almost oily look around them (that rainbow color) and when you run your finger over them they stick out but dont in between them
