Smog vs Gears?
Old Oct 14, 2008 | 08:23 AM
HankL's Avatar
HankL
Originally Posted by dodgeram04
Hey guys, I know I have another post on here regarding another issue, but this offer just came to me from a buddy.
Hes got a 05 ram, and is offering a axle swap cause he is trading in his dodge for something else. His rear end have a eaton posi, with 4.88 gear ratio. My rear end is stock 3.55 dog leg. For my daily driver, how do you all think the ratio differance will affect my gas mileage, or for that matter CA Smog?
Tell us whether you have a 4x4 Ram or 2wd Ram
with 4.88 in the rear you may be limited in the front as to what is available
I don't think gearing would affect Smog in CA
except that if the 'check engine' light gets lit
for any reason on the OBD-II system
they won't pass you at inspection
I
Old Oct 14, 2008 | 01:26 PM
KC9JVC's Avatar
KC9JVC
Now I'm curious...where does the speedo read the speed off of? With the gear change wouldn't the drive shaft be spinning faster, etc. which makes me wonder...
Old Oct 14, 2008 | 05:40 PM
Tonyo88's Avatar
Tonyo88
The only thing the drive shaft spinning faster would affect is your RPM's. Speed doesn't go by RPMs. You can drive around first gear red-lining and be going the same speed idling a few gears higher. It's just how fast your wheels are spinning.
Of course, I could be completely out to lunch here.
Old Oct 15, 2008 | 01:39 AM
KC9JVC's Avatar
KC9JVC
I get what you're saying but from my understanding the speed of a vehicle is measured off of how fast the drive shaft is spinning, which has nothing to do with what gear you're in, which is why I asked...if its measuring off of the rear axle or something after the final gears then I could see changing the gears not mattering, but from my understanding its read off the drive shaft.
Old Oct 15, 2008 | 07:07 AM
HankL's Avatar
HankL
around model year 1998
as a cost cutting move
Chrysler began reading the vehicle speed
off the anti-lock brake sensor
mounted on the differential
which always reads axle rpm
not trans output shaft rpm like in older years
The speedo does still need to be calibrated
for the revolutions per mile
of the tires
on the DRB scanner
and many dealerships techs
don't know all the tricks for doing this
Old Oct 15, 2008 | 10:11 AM
KC9JVC's Avatar
KC9JVC
Huh...I didn't realize that. Nice to know. Makes my plans for doing the gears in my truck maybe a little cheaper seeing as the tech that I got the quote from said I'd have to get the speedo reclocked as well.
4.10 here I come!!! Goodbye 3.55...once I win the lottery that is.
Old Oct 15, 2008 | 06:04 PM
Gone Fishin's Avatar
Gone Fishin
I'd do it in a heartbeat!! Run the tires until you need new ones, then upsize if you feel you need to, If nothing else, you could always change gears too, the point is, you've got a much better than stock center section!!!!!
