Front end high pitched squeek
Old Oct 13, 2008 | 11:18 PM
Geed's Avatar
Geed
Default Front end high pitched squeek
My 3 week old '08 1500 QC Hemi has developed a squeek coming from the front end when driving down the road. It's a high pitched squeek that happens when the truck bounces up and down over small bumps in the road. If I bounce the truck while standing next to the driver's front tire I can hear it is definitley coming from the wheel well area - kind of hard to bounce it and put my head right in the wheel well so I cannot be 100% sure where it's coming from. At least one time it sounded like the squeek was coming from both sides although if I bounce the pass. side I cannot get it to make the noise.
I had a ReadyLift leveling kit installed on a Weds, then had the truck aligned on a Friday, then I noticed the squeek begin on the next day (Sat). My question: could something have been done during an alignment which could have started this very annoying squeek? Or can the leveling kit be the culprit?
I was hoping that it would just go away on it's own but it's been over a week now and it is still there. Before I bring the truck back to the dealer (who did the alignement) I wanted to get some input from you guys. It's just not normal to see a nice new shiny truck come squeeking down the road. Trust me.... it's very annoying or else I would just ignore it.
Old Oct 14, 2008 | 07:11 PM
Geed's Avatar
Geed
Just an update...
Had the wife bounce the truck tonight while I stuck my head in the wheel well. Sounds like the squeek is coming from the upper control arm bushings (but not 100% sure - it's very hard to pinpoint the origin!). I sprayed some WD40 on the bushings so I'll see what it sounds like in the morning.
Old Oct 15, 2008 | 09:21 AM
Geed's Avatar
Geed
aaaahhhh.... the squeeking is still there this morning. If anything it actually sounds a little worse. Just wondering if anyone else out there that has a ReadyLift leveling kit ever had a squeeking problem? I can't see why putting spacers on the top of the shock/coil could cause a high pitched squeek like this but there is nothing else I've had done in the front end besides a wheel alignment.
Old Dec 10, 2009 | 11:12 AM
53fireman's Avatar
53fireman
Sounds like the same squeek mine has had for a year now. My '08 is still squeeking like crazy if I hit un-even bumps, like potholes or sewer covers. The only thing I've done to it was put on Westin step bars. I took it back 3 times to the dealer to no avail. Any suggestions out there?
Old Dec 10, 2009 | 08:03 PM
Kebo's Avatar
Kebo
Yep, mine has had that squeek since I bought it in '07. Mine is coming from the passenger wheel well. And like you I suspect the upper control arm. The only thing that can be done is to replace the control arm bushings and make sure that they are greased before installing them.
Old Dec 11, 2009 | 02:59 PM
DodgeThunder's Avatar
DodgeThunder
I had the exact same squeek in mine after I installed the leveling kit, the shop said it was the upper strut mounts, so I bought new ones at 80 dollars a pop, then I decided the leveling kits are garbage and didnt like the clunking that it also did going over bumps, took the level out and everything is back to normal, no clunk or squeek, I dunno if you guys have leveling kits, but these newer strut suspensions seem to be a little iffy.. It might not be the same thing with you guys but I found that if I sprayed white lithium greese into the hole in the top of the strut tower mount in the middle the squeek would go away for a few days.. try it out
